Adding an adapter and defining its job schedules using the command line
- Open a Command Prompt window and enter the name of the drive in which the executable file is installed.
Note: By default, the executable file is installed in the same location as the Central Coding application.
- Enter the location of the executable file in the drive that you specified:
<Installation Folder>\CentralCodingServer\CodingWebUI\bin
Note: You must run the application from this directory.
- Enter the following command for adding an adapter and defining its job schedules:
PhaseForward.CentralCoding.SetAdapter.exe [AdapterName] [AdapterURL] [GetVerbatimsSchedule] [ReturnCodesSchedule]
In the command syntax:
- AdapterName—Name of the adapter to add.
- AdapterURL—URL of the adapter to add.
- GetVerbatimsSchedule—Rate at which to run the Get Requests job schedule. This parameter corresponds to the Time span configuration setting on the Schedule GetRequests Job page in the user interface.
- 0—Indicates that you will run manual Get Requests jobs for the adapter, and the adapter should not be added to a Get Requests schedule.
- 1—Set a Get Requests job schedule to run every minute for the adapter.
- 5—Set a Get Requests job schedule to run every five minutes for the adapter.
- 15—Set a Get Requests job schedule to run every fifteen minutes for the adapter.
- 30—Set a Get Requests job schedule to run every thirty minutes for the adapter.
Note: This parameter is optional.
- ReturnCodesSchedule—Rate at which to run the Return Codes job schedule. This parameter corresponds to the Time span configuration setting on the Schedule ReturnCodes Job page in the user interface.
- 0—Indicates that you will run manual Return Codes jobs for the adapter, and the adapter should not be added to a Return Codes schedule.
- 1—Set a Return Codes job schedule to run every minute for the adapter.
- 5—Set a Return Codes job schedule to run every five minutes for the adapter.
- 15—Set a Return Codes job schedule to run every fifteen minutes for the adapter.
- 30—Set a Return Codes job schedule to run every thirty minutes for the adapter.
