Installing a Central Coding application server
Use this procedure to install an instance of the Central Coding software. After you install one instance of the Central Coding software, you can run the installation program as many times as necessary to install additional instances.
Perform this procedure on each application server.
Note: This installation procedure requires that you enter the names of the database tablespaces and their associated database users and passwords. For demonstration purposes in this guide, example names for the tablespaces, users, and passwords are provided in this procedure in the appropriate steps. For more information, see Create the database and tablespaces.
Caution: All entries used as Oracle database objects (such as user names, passwords, and tablespaces) should follow Oracle recommendations for naming conventions. In addition, Oracle recommends using strong passwords, as described in the Secure Configuration Guide.
