Configure application settings
- Download and extract the Central Coding 6.3 product archive.
- Locate setup.exe.
- Right-click and select Run as administrator.
- If you are installing the Central Coding application for the first time, the Welcome page appears.
- If you have already installed an instance of the Central Coding application, the Existing Installed Instances Detected page appears.
- Select Install a new instance of this application, and click Next.
The Welcome page appears.
- Click Next.
The page that appears depends on the operating system.
- If you are performing a fresh installation on a Japanese operating system, the Required System Components page appears. Proceed to step 5.
- If you are performing a fresh installation on an English operating system, the Determine Database Sort page appears.
Use this page to specify the locale, which determines the correct linguistic sorting in the database. The choice affects the language of verbatims that can be supported, the default date format, and which report templates are installed.
- Select the locale.
- English—Sets the default database sort group to English. The English option maps to the Binary Oracle sort value.
Select this option to:
- Support only English verbatims.
- Set the default date format to DD/MON/YYYY HH24:MI:SS.
- Load the English report templates. The reports can contain only English data.
- European—Sets the default database sort group to WesternEuropean. The European option supports more character sets than the English option. It maps to the Generic_M Oracle sort value, which generally handles the order of the Latin, Cyrillic, Greek, and other European characters.
- Global—Sets the default database sort group to JapaneseWesternEuropean. The Global option maps to the Japanese_M Oracle sort value.
Select this option:
- If you are using an English operating system and you want to support both English and Japanese verbatims, or if you are using a Japanese operating system.
- To set the default date format to YYYY/MON/DD HH24:MI:SS.
- To load the Japanese report templates. The reports can contain both Japanese and English data.
Note: For the best performance, Oracle recommends that you select Global only if you are working with Japanese studies.
- Click Next.
The Required System Components page appears. The installation wizard verifies that the server has all the necessary software components, including the operating system, IIS, .NET, and the Oracle client.
If required components are missing or are the wrong version, installation stops. The missing and invalid components are listed on the Required System Components page. You must install them before continuing the installation.
- Click Next.
The Company Information page appears.
- Enter the following information:
- Company name—Name of the company licensed to use the software.
The company name may include any characters. This is informational only.
- Company URL—URL that is unique to the company.
This is used to define the security domain in inter-product communication. The Company URL:
- Must be in English.
- Must follow the proper URL convention and be in valid URL (ASCII) narrow characters.
The URL does not need to point to an actual running website or service.
- Should not begin with a protocol designation such as http://.
For example, www.oracle.com.
- Click Next.
The Select Features page appears.
- Select the features to install. At least one feature must be selected in order to continue with the installation. If you select only the Dictionary Loader tool, the installation program skips to the end of the wizard.
- Central Coding Server.
- Dictionary Loader.
The Dictionary Loader tool must be installed in order to load standard and custom dictionaries. However, the Dictionary Loader tool:
- Does not need to be installed on every machine or on every application server.
- Can be on a different machine from the Central Coding application server(s).
- Can be installed without also installing the Central Coding Server.
To verify whether the Dictionary Loader tool is installed, go to Start > Apps. If Dictionary Loader appears under Oracle HS, it is already installed.
- Click Next.
The Authentication Scheme page appears.
- Select Native Authentication, and click Next.
Note: Trust Authentication is available only for Oracle-hosted installations.
