Code map not found—Undeliverable requests
Issue |
Codes are not returned to the InForm application and the Code map not found error appears in the Central Coding application for undeliverable requests when:
Possible cause |
When the Central Coding mappings are updated in the InForm application using the same RefName, the InForm application does not create a new revision for the mappings. Instead, the InForm application creates an entirely new set of mappings with new GUIDs. As a result, when a verbatim is recoded in the Central Coding application after the updated mappings are installed in the InForm application, the request is undeliverable from the Central Coding application. The Code map not found error appears when you view the hover help for a request with a delivery status of Undeliverable ( For more information, see the User Guide. |
Solution |
Contact Oracle CAG. |
Note: This issue does not affect InForm release 6.1.1 and higher.
) on the Coding Requests, Approvals, or All Requests page in the Central Coding application.
