Modifying the response file
Perform this procedure on each application server.
Note: All entries used as Oracle database objects (such as user names, passwords, and tablespaces) should follow Oracle recommendations for naming conventions. In addition, Oracle recommends using strong passwords, as described in the Secure Configuration Guide.
- Copy the Central Coding installation folder to your local machine.
- Locate the setup.iss response file.
- Save the setup.iss response file with a different name.
Note: Oracle recommends saving the response file with a name that references the Central Coding instance with which it is associated.
- Modify the response file with the following information:
Descriptions of response file parameters
Parameter
Description
svLanguage
Locale:
- English
- Western European
- JapaneseWesternEuropean
szCompanyName
Company name.
szCompanyURL
Company URL.
szDir
(First)
Base installation directory.
This should match the information you specify in the parameter for the Central Coding instance directory.
svAuthChoice
Authentication scheme used.
This must be NATIVE for self-hosted installations.
instanceName
Instance name.
svPort
Job Scheduler communication port number.
This must be an empty port that has not been used by any other software.
szDir
(Second)
Directory for the Central Coding instance.
This should match the information you specified in the installation directory parameter.
Central Coding Database user parameters
svDBServer
Database server connection string for the Central Coding Database user.
svOracleSysDBAUser
Oracle user with SYSDBA privileges.
This must be entered only if svCreateUser is TRUE.
svOracleSysDBAPassword
Password for Oracle user with SYSDBA privileges.
svdbUID
Central Coding Database user ID.
svdbPID
Central Coding Database user password.
svDBTablespace
Name of the tablespace for the Central Coding database.
svCreateUser
Controls whether the user specified by svdbUID is created (TRUE), or if an existing user identified by svdbUID will be reused (FALSE).
Platform Database user parameters
svDBServer
Database server connection string for the Platform Database user.
svOracleSysDBAUser
svdbUID
Platform Database user ID.
svdbPID
Platform Database user password.
svDBTablespace
Name of the tablespace for the Platform database.
svCreateUser
Dictionary Database user parameters
svDBServer
Database server connection string for the Dictionary Database user.
svdbUID
Dictionary Database user ID.
svdbPID
Dictionary Database user password.
Certificate parameters
svCertSubject
Certificate subject.
svCertIssuer
Certificate issuer.
svCertName
Certificate name.
svCertExpiration
Certificate expiration date, in the format MM/DD/YYYY H:MM:SS AM/PM.
svCertThumbprint
Certificate thumbprint.
Note: Make sure there are no spaces in the value of the parameter.
