Selecting a certificate for InForm Adapter authentication
Certificate authentication can be used in the following cases between Central Coding and InForm Adapter interfaces:
- Adapter Admin—When the Adapter URL starts with https.
- Coding and Discrepancy web services—When you prefer the certificate authentication method to the username/password method, when the Adapter URL starts with https.
To select a certificate, or replace the certificate that is currently in use, run the utility PhaseForward.CentralCoding.UpdateIACertificate.exe located in <Installation Folder>\CentralCodingServer\CodingWebUI\bin.
Run the utility from the command line with one of the parameters:
- /?—Displays command help and exit codes.
- /s <certificate name> <certificate thumbprint>—Selects the specified certificate to be used for InForm Adapter authentication.
- /r—Removes the certificate that is used for InForm Adapter authentication.
