Replacing the certificate to secure internal communication with the Job Scheduler service
You select a certificate to secure internal communication with the Job Scheduler service during the Central Coding application server installation.
To replace the certificate:
- Install a new certificate. For more information, see Install a certificate to secure communication with the Job Scheduler and InForm Adapter.
- Run UpdateJSCertificate.cmd (located in <Installation Folder>\CentralCodingServer\CodingWebUI\bin) using the following syntax:
UpdateJSCertificate.cmd <CertificateName> <CertificateThumbprint>
In the previous example:
- CertificateName—Name of the new certificate.
- CertificateThumbprint—Thumbprint of the new certificate.
