Coding Dictionary Metadata workspace—Option descriptions
Option descriptions for the Coding Dictionary Metadata workspace
Field |
Description |
Display Name |
Name of the dictionary metadata item; either Dictionary or CoderName. |
Version |
Version number for the dictionary metadata item. |
Level |
Dictionary level for which a coding map can be defined for the metadata item; either Dictionary or CoderName. |
Level Type |
Information that indicates the type of supported target item for the dictionary metadata item. The only available option is Term. |
Description |
Description of the dictionary metadata item; either Dictionary or CoderName. |
