Dictionary Types workspace—Field descriptions
Field descriptions for the Dictionary Types workspace
Field |
Description |
Type |
Name of the dictionary type. Note: In the dictionary type XML file, this information comes from the DictionaryType type field. You can modify this information by double-clicking the Type field. |
Description |
Description of the dictionary type. Note: In the dictionary type XML file, this information comes from the Description field. You can modify this information by double-clicking the Description field. |
Import date |
Date on which the dictionary type was imported. |
Enabled |
Indicates whether the dictionary type is enabled. Only enabled dictionary types can be used to create coding definitions in the Central Designer application. |
