Custom Properties workspace—Field descriptions
The fields that appear in the Custom Properties workspace vary according to what you select. You can select a study object, a grouping, or a custom property.
Field descriptions for the Custom Properties workspace
Field |
Description |
A study object is selected. |
Groupings |
Name of the grouping for the study object. Groupings organize custom properties in the Central Designer application. |
A grouping is selected. |
Custom Properties |
Name of the custom property created under the grouping for a study object. |
A custom property is selected. |
Name |
Name of the custom property. |
Data Type |
Data type of the custom property:
Max Length |
Maximum number of characters allowed for the value of the custom property. |
Description |
Description of the custom property. |
Make Property Visible |
Use Value List |
The Use Value List grid has the following fields.
