Custom properties in the Central Designer application
A custom property created for a study object (for example, an item) appears in the Properties Browser for all study objects of that type (in this case, all items).
Custom properties in the Central Designer application |
1—A portion of the Custom Properties workspace in the Central Designer Administrator application. |
2—A portion of the Properties Browser in the Central Designer application. Custom properties defined under the Clintrial grouping appear in the Central Designer application under the same Clintrial grouping, and custom properties defined under the InForm grouping appear in the Central Designer application under the same InForm grouping. |
