Changing your password in the Central Designer application
If the administrator who created your user account requires that you change your password, you are prompted when you start the application to change your password.
To change your password because it is required:
- Log on to the Central Designer application.
The Change Password dialog box appears.
- Enter your old and new passwords. You must enter your new password twice.
- Click OK.
To change your password at any time after logging on:
- Select File > Change Password.
- Enter your old and new passwords. You must enter your new password twice for confirmation.
- Click OK.
