Logging on to the Central Designer application
You can log on after an administrator creates a user account for you.
- Using Internet Explorer, navigate to the following address:
http://<server name>/CentralDesignerInstall
In the previous address, <server name> is the name of the application server computer.
- Click the Start Central Designer Client link.
A dialog box appears, indicating that the application is starting.
The logon window appears.
- Enter your user name and password.
- If the web browser connects to the network through a proxy server that requires authentication, click Proxy Settings to enter the user name, the password, and the domain used to authenticate the connection to the proxy server.
- Click Log On.
Note: When a user account is created in the Central Designer Administrator application, the administrator can require the user to change the password after logging on the first time. You might be prompted to change your password.
