Starting the Central Designer client application
The client applications are ClickOnce applications, and you do not need to install them to start them, as you would for applications using a traditional Windows installer.
- Using Internet Explorer, navigate to the following address:
http://<server name>/CentralDesignerInstall
In the previous address, <server name> is the name of the application server computer.
- Click the Start Central Designer Client link.
The application files are downloaded to a cache and the application is installed. The installation might take some time.
After the installation is complete, the application opens, and you can log on.
