Configuring SMTP settings for automated deployment email notifications
The Central Designer application can send email notifications for the following automated deployment events:
- Deployment request is created, approved, or rejected.
- Deployment is started.
- Deployment is completed successfully or with failures.
- Deployment request is cancelled.
- Deployment is cancelled.
To set up Central Designer to send email notifications:
- Install the SMTP server feature in Microsoft Windows. For more information, see the Microsoft documentation for your operating system.
- Verify that you can send email from the SMTP server.
- After you install the Central Designer application server, configure the Central Designer web site to send email.
- Select Start > Administrative Tools > Internet Information Services (IIS) Manager.
- Expand <machine_name> > Sites > Default Web Site.
- Select CentralDesigner.
- In the Features View, double-click SMTP E-mail.
The SMTP E-mail page appears.
- Enter a dummy address as the email address from which messages are sent (for example, designer@mycompany.com).
- Select Deliver e-mail to SMTP server.
- Select Use localhost.
- Select the same authentication settings that are configured for the SMTP server.
- Click Apply.
Note: Every time you install the Central Designer application, you must reconfigure the SMTP email settings for the Central Designer web site.
