Completed
Completed
Characteristic |
Description |
Icon |
Availability |
Compound items. |
Return type |
Boolean. |
Description |
Note: Items that are conditional on child items of the compound item are not evaluated. |
Purpose |
This property allows you to simplify the expressions of data-entry rules that check to see if controls that have been started are completed. Typically these expressions also use the Empty rule model property. |
