AllValues[]
AllValues[]
Characteristic |
Description |
Icon |
Availability |
An item that is a child of one of the following:
Return type |
Description |
Returns an array of values from item instances that are part of a repeating study event, repeating form, or repeating section. |
Included in the array |
Not included in the array |
Values of empty items. An item is empty if the form has been created but a value has not been provided for the item. |
Example |
A study contains the following repeating forms, which contain the AEDate item:
When you use this property, the following instances are returned:
Notes |
Note: Values[], AllValues[], Objects[], and AllObjects[] all return an array of data. Consider the following scenarios when deciding upon the property to use:
Additionally, consider that the following CurrentIndex properties are also available: |
