Characteristic
Description
Icon
Availability
An item that is a child of one of the following:
- Form that is part of a repeating study event.
- Repeating form.
- Repeating section.
Return type
object[]
Description
Returns an array of values from item instances that are part of a repeating study event, repeating form, or repeating section.
Included in the array
- Values of undeleted items. An item is undeleted if someone has provided a value for it, and the form or section that contains the item has not been deleted.
- Values of deleted items. An item is deleted if the form or section that contains it is deleted from a study.
- Values of empty items. An item is empty if the form has been created but a value has not been provided for the item.
Example
A study contains the following repeating forms, which contain the AEDate item:
- First instance of the form—Someone has entered a value for the AEDate item.
- Second instance—Someone has filled in values for other items but not the AEDate item (the item is empty).
- Third instance—Someone entered a value for the AEDate item and deleted the form (the item is deleted).
- Fourth instance—Someone has entered a value for the AEDate item.
When you use this property, the following instances are returned:
- First instance
- Second instance
- Third instance
- Fourth instance
Notes
Note: Values[], AllValues[], Objects[], and AllObjects[] all return an array of data. Consider the following scenarios when deciding upon the property to use:
- To include deleted values, use either AllValues[] or AllObjects[].
- To include null values, use Objects[] or AllObjects[].
Additionally, consider that the following CurrentIndex properties are also available:
