DesignerFunction
Required: Yes.
Valid on: The static method that defines a Central Designer function.
Purpose: Identifies the static method as a user-defined Central Designer function and supplies the descriptive text that appears with the function in the Central Designer application. Only public static functions with this attribute are treated as user-defined function definitions.
Parameter:
Parameter for DesignerFunction
Name |
Type |
Description |
Description |
String |
