DesignerFunctionClassification
Required: No.
Valid on: The static method of the function on the class containing a collection of function definitions.
Purpose: Defines the classification of the function, which is used to group functions in the:
- Functions tab of the Study Editor.
- Function tab of the References section of the Rule Wizard and related dialog boxes.
If you do not include a DesignerFunctionClassification attribute, the classification of a function is either:
- The classification defined for the class that contains the function.
- The name of the class, if no classification is defined for the class that contains the function,
Parameter:
Parameter for DesignerFunctionClassification
Name |
Type |
Description |
Description |
String |
Classification name |
