Functions tab on the Study and Library Information Explorer bars
The Functions tab displays imported, user-defined functions that you can use with rules and rule templates in a study or library. Functions defined in the Functions tab are available study- or library-wide, regardless of the scope of any rules.
A function is a reusable piece of code that extends the behavior of a rule. Many predefined functions are available by default in the System Library.
The Functions tab is available in the following locations:
- Study Information Explorer bar > study node.
- Library Information Explorer bar > library node.
Functions tab - Option descriptions
Functions tab - option descriptions
Option
Description
Fields
Note: Not all fields appear in the default view. Optionally, you can add the other fields to the browser view, and you can rearrange the order of fields. For more information, see Showing and hiding a field.
Class
The class in which the function is included.
Classification
User-defined text used to group, sort, and filter functions.
Data Type
Return type of the function, either Integer, Float, String, Boolean, Date/Time, or Array (A list of values, all of the same type).
Description
Description of the function.
Filename
Name of the assembly file that contains the function.
ID
Unique identifier for the function.
Language
Language in which the function was written.
Name
Name of the function.
Parameters
Parameters for the function.
Published (only in libraries)
Indicates that the study object has been published.
Title
Title of the function.
Type
Function type. All functions are .NET class functions.
Toolbar buttons
Import function
Import an existing function.
Edit
Open the selected function to view or edit it.
Delete
Delete the selected function.
Publish (only in libraries)
Publish the selected function. This button is enabled for library objects that have been saved.
