Functions tab—Option descriptions
Functions tab - option descriptions
Option |
Description |
Fields
Note: Not all fields appear in the default view. Optionally, you can add the other fields to the browser view, and you can rearrange the order of fields. For more information, see Showing and hiding a field in the User Guide. |
Class |
The class in which the function is included. |
Classification |
User-defined text used to group, sort, and filter functions. |
Data Type |
Return type of the function, either Integer, Float, String, Boolean, Date/Time, or Array (A list of values, all of the same type). |
Description |
Description of the function. |
Filename |
Name of the assembly file that contains the function. |
ID |
Unique identifier for the function. |
Language |
Language in which the function was written. |
Name |
Name of the function. |
Parameters |
Parameters for the function. |
Published (only in libraries) |
Indicates that the study object has been published. |
Title |
Title of the function. |
Type |
Function type. All functions are .NET class functions. |
Toolbar buttons |
Import function |
Import an existing function. |
Edit |
Open the selected function to view or edit it. |
Delete |
Delete the selected function. |
Publish (only in libraries) |
Publish the selected function. This button is enabled for library objects that have been saved. |
