_IsValueLessThanOrEqualToArray (PFDateTime, Array)
Checks if a specified date time value is less than or equal to at least one of the date time values in an array.
Syntax
_IsValueLessThanOrEqualToArray(valueToTest,valueList)
Parameters
Parameters for _IsValueLessThanOrEqualToArray (PFDateTime, Array)
Parameter |
Definition |
Data type |
valueToTest |
Date time value with which to compare the values in the array. |
PFDateTime |
valueList |
Array of date time values against which to compare the value specified in the valueToTest parameter. |
Array of PFDateTime values |
Returns
True or False (Boolean), indicating whether the specified date time value is less than or equal to at least one of the date time values in an array.
Notes
- The valueToTest value is compared to each element of the array. If the value is less than or equal to every element of the array, the method returns True. If at least one element is greater than the value, the method returns False.
- All comparisons are done using the _CompareDates method and are normalized. For more information, see About date time processing.
