_IsValueLessThanOrEqualToArray
Checks whether a specified value is less than or equal to at least one of the values in an array. This function takes different parameters depending on the data type of the value to which you are comparing the values in the array.
_IsValueLessThanOrEqualToArray functions
Data type to compare |
Function to use |
Date time |
Float |
Integer |
