_NormalizeDateToMax(Array)
Normalizes an array of date times by replacing any parts that are UNKNOWN or EMPTY with the maximum value for that part.
Syntax
_NormalizeDateToMax(datesToNormalize)
Parameters
Parameters for _NormalizeDateToMax
Parameter |
Definition |
Data type |
datesToNormalize |
The array of date times to normalize. |
Array of PFDateTime values |
Returns
A new array of date times, with all UNKNOWN or EMPTY parts replaced with their respective maximum values:
- Year—9999
- Month—12
- Day—(Last day of the month that year)
- Hour—23
- Minute—59
- Second—59
Notes
The _NormalizeDateToMax function accounts for leap years and returns the correct number of days in February of any year.
You can use arrays called by either the Values() or Objects() property.
Example
The requirement in this example is to find the latest date among all dates in a repeating form, using the MaxValueInArrayDate function. If the date on the repeating form allows users to enter UNKNOWN for days or months, comparing dates without normalizing them can be unpredictable and depends on the sequence of dates in the array. Therefore, use the _NormalizeDateToMax(Array) function to return normalized dates with predictable UNKNOWN parts.
Consider the following arrays of dates, in which the only difference in content is the value of the Day part, which causes the order of the dates to be different in each array:
ArrayOfDates1
ArrayOfDates1 |
Day |
Month |
Year |
Date1 |
18 |
10 |
2008 |
Date2 |
UNK |
10 |
2008 |
ArrayOfDates2
ArrayOfDates2 |
Day |
Month |
Year |
Date1 |
UNK |
10 |
2008 |
Date2 |
18 |
10 |
2008 |
Sample function calls
Sample function calls |
Function call |
Returned value |
MaxValueInArrayDate(ArrayOfDates1) |
Date1 |
MaxValueInArrayDate(ArrayOfDates2) |
Date2 |
MaxValueInArrayDate(_NormalizeDateToMax (ArrayOfDates1)) |
Date2 |
MaxValueInArrayDate(_NormalizeDateToMax (ArrayOfDates2)) |
Date2 |
MaxValueInArrayDate(_NormalizeDate(ArrayOfDates1, new DateTime(1,1,1))) |
Date1 |
MaxValueInArrayDate(_NormalizeDate(ArrayOfDates2, new DateTime(1,1,1))) |
Date1 |
