Predefined constants in the System Library
Predefined constants appear in:
- The Constants tab of the System Library.
- The Rule Wizard > Expression tab > Constants tab in the System Library or in a study. Predefined constants do not appear in this location for user-created libraries.
When your Libraries Browser searches include the System Library, the predefined constants are included in the search.
In the Rule Wizard, when you drag a function to the Expression workspace, the Invoke Function dialog box appears. In the dialog box, you can expand the Constants tab, and drag the appropriate constant to the Value field for the parameter.
DateTimeParts constants—Use the following constants to specify a parameter in a predefined function that requires a date part. For example, the following functions include date part parameters:
- _CalculateDateTime
- _CompareDatesWithRange
- _GetDateDifference
Name
Description
Data type
Years, Months, Days, Hours,
Minutes, SecondsDate time part for years, months, days, hours, minutes, or seconds.
Integer
FormStates constants—Use the following constants to specify a form state using HasState(Integer).
Name |
Description |
Data type |
Deleted |
(Available only for repeating forms) The repeating form instance has been deleted. |
Integer |
Frozen |
The form is frozen. |
Integer |
HasComment |
The form has a comment at the form level. |
Integer |
HasData |
The form has data. |
Integer |
HasMissingData |
The form has missing data. |
Integer |
HasQueries |
The form has queries. |
Integer |
Locked |
The form is locked. |
Integer |
SdvComplete |
The form has been marked source verified. |
Integer |
SdvPartial |
The form has been partially source verified. |
Integer |
SdvReady |
The form has been marked ready for source verification. |
Integer |
Signed |
The form has been signed. |
Integer |
Skipped |
The form has been marked not completed with a form-level comment. |
Integer |
Started |
The form was started with subject data, comments, or queries. |
Integer |
