_RangeCheck
Description of _RangeCheck rule template
Characteristic |
Description |
Availability |
Integer and float items |
Description |
Checks whether the value for an integer or float item is greater than a minimum value and less than a maximum value. By default, the minimum value is:
By default, the maximum value is:
You can change these values when you create a rule based on the template. |
Returns |
Display text |
Value must be between {MinValue} and {MaxValue} |
