_RangeCheckInclusive
Description of _RangeCheckInclusive rule template
Characteristic |
Description |
Availability |
Integer and float items |
Description |
Checks whether the value of a float or integer item is greater than or equal to a minimum value and less than or equal to a maximum value. By default, the minimum value is:
By default, the maximum value is:
You can change these values when you create a rule based on the template. |
Returns |
Display text |
Value must be greater than or equal to {MinValue}, and less than or equal to {MaxValue} |
