Additional study objects in the Data Mappings tab
In addition to rule model properties and methods, the Data Mappings tab displays study events, forms, sections, and items that are part of the data set that is expanded in the References section. Study objects appear if they are selected as standard data dimensions of a data set. For example, if you select the Form standard dimension, the Forms node appears under the data set and under the Form(Forms) method.
You can use the study events, forms, sections, and items to define values of parameters for methods. When you double-click a method to use it in the rule expression, the Invoke Function dialog box appears, prompting you to define values for the parameters of the method. You can drag a study object to the Value field for each parameter.
