CurrentStudyEvent()
CurrentStudyEvent()
Characteristic |
Description |
Icon |
Availability |
When the Event and Event Index standard data dimensions are selected for the data set. Notes:
Returns |
A data set subset with data from only the current study event. If the study object you map to the data set has multiple values (for example, if you map an item on a repeating form), you might get an array or many values, rather than just one value. |
Syntax |
NameOfDataSet.CurrentStudyEvent() |
Parameters |
None. |
