Data set methods
Data sets can contain multiple data series, which can contain multiple items. You use data set methods to return a data set that is a subset of the original data set. Data set methods always return a data set, not a single value.
Methods for data sets appear in the Rule Wizard in the Expression tab > Data Mappings tab. The list of methods that appear is based on the selection of standard data dimensions and the creation of custom data dimensions in the definition of the data set. In addition to the data set methods listed in the following table, one method appears for each custom dimension that is created for the data set.
Standard data dimensions and data set methods
Standard data dimensions selected |
Data set method in Data Mappings tab |
Event |
Event and Event Index |
Form |
Form and Form Index |
Section |
Section and Section Index |
Item |
Note: You cannot use a data set method more than once in a rule expression.
