_CalculateBSA
Calculates the body surface area.
Syntax
_CalculateBSA(height,weight)
Parameters
Parameters for _CalculateBSA
Parameter |
Definition |
Data type |
height |
Height of the subject, in centimeters. |
Float |
weight |
Weight of the subject, in kilograms. |
Float |
Returns
Body surface area (Float).
Notes
- Calculates the BSA using the following formula:
(Float)(0.007184 * Math.Pow(height,0.725) * Math.Pow(weight,0.425));
(Math.Pow is a method that raises a value to the specified power.)
- Height is assumed to be in centimeters, and weight is assumed to be in kilograms.
- Oracle recommends that you include rule logic to clear the calculated value if a referenced item value is cleared. For example, if a rule calculates BMI based on the values entered in the Height and Weight items, the rule should clear the BMI value if the data in the Height item is deleted. For an example of the appropriate rule logic, see Sample data-entry rules that use methods.
