_CalculateWaistHipRatio
Calculates the waist-to-hip ratio.
Syntax
_CalculateWaistHipRatio(waist,hip)
Parameters
Parameters for _CalculateWaistHipRatio
Parameter |
Definition |
Data type |
waist |
Waist measurement of the subject. |
Float |
hip |
Hip measurement of the subject. |
Float |
Returns
Waist-to-hip ratio (Float).
Notes
- Waist-to-hip ratio is calculated as waist/hip.
- Both measurements must be in the same units. For example, if one measurement is in centimeters, the other must be, as well.
Exceptions
An exception of type Argument Exception is returned if the hip measurement equals zero. This exception results in:
- Failure of the rule execution.
- An InForm Server Error in the InForm client application.
- An entry in the Event log on the InForm server computer.
Example
The following rule is attached to the Vital Signs form and does not need any objects from outside the form. The form includes a waistCircumference item to record the measurement of waist circumference and a hipCircumference item to record the measurement of hip circumference. Both allow the value to be recorded in centimeters or inches, but both values are normalized to centimeters.
Note: Oracle recommends that you include rule logic to clear the calculated value if a referenced item value is cleared. For example, if a rule calculates BMI based on the values entered in the Height and Weight items, the rule should clear the BMI value if the data in the Height item is deleted. For an example of the appropriate rule logic, see Sample data-entry rules that use methods.
evaluate on Form Submission
value = _CalculateWaistHipRatio(this.waistCircumference.Value, this.hipCircumference.Value)
always
set this.whRatio.Value = value
