Importing a user-defined function
Before you can use a function that is created outside of the Central Designer application, you must import it to a study or library.
- In a study, select the Study Information Explorer bar.
or
In a library, select the Library Information Explorer bar.
- Select InForm.
- Select the Functions tab.
- Click Import Function.
The Function File dialog box appears.
- Locate the .NET assembly (a DLL file) containing the functions to import, and click Open.
The functions included in the .NET assembly are stored in the Central Designer database and are added to the list of functions in the grid.
