_SaveToDb(String, String)
Determines whether to send data to the InForm Publisher queue.
Syntax
_SaveToDB(<Message>,<Trialname>)
Parameters
Parameters for _SaveToDb
Parameter |
Definition |
Data type |
message |
Parameter that triggers the InForm Publisher application to do one of the actions listed below. The rule expression loads the message parameter with a value based on the value of specific items in the form. The text of the message parameter is fixed. The library in the InForm and Oracle Argus Safety integration package includes the following constants defining enumerations for the required strings. Using these SafetyConstants enumerations to specify the required strings is strongly recommended.
String |
trialname |
Name of the study, populated by the GetTrialName() predefined function. |
String |
Example
_SaveToDB('SafetyConstants.IsReportableOrSerious',GetTrialName());
