CurrentIndex
CurrentIndex
Characteristic |
Description |
Icon |
Availability |
Repeating study events, repeating forms, and repeating sections. Note: To view this property, you must select the parent study object. For example, to view the property on a study event, you must select its parent (either a study element or a study design). |
Return type |
Int32 (for Central Designer Integer and YesNo types). |
Description |
The index of the current study events, form, or section. The index starts at 0. |
Purpose |
Use this property to determine the section, form, or study event for which someone is currently entering or modifying data. For example, you might want to perform a rule action for the first form for which data was entered and another rule action for subsequent instances of the form. |
