Count
Count
Characteristic |
Description |
Icon |
Availability |
Repeating study events, repeating forms, and repeating sections. Note: To view this property, you must select the parent study object. For example, to view the property on a study event, you must select its parent (either a study element or a study design). |
Return type |
Int32 (for Central Designer Integer and YesNo types). |
Description |
The current number of instances of the repeating study event, form, or section. |
Purpose |
Use this property to determine the number of sections, forms, or study events in a study. For example, you might want to know the number of adverse events that exist for a subject. |
