Value
Value
Characteristic |
Description |
Icon |
Availability |
All items except compound items. |
Return type |
One of the following:
Description |
Returns the value of the item. |
Purpose |
Use this property to return the value of an item as it is stored in the database.
For example, if the base unit for a weight item is kilograms, and the InForm user enters a value of 100 and:
To determine the value that the InForm user entered into the field, use EnteredValue and the accompanying EnteredUnit. |
