Selected[]
Selected[]
Characteristic |
Description |
Icon |
Availability |
Available for items with multi-select codelists. |
Return type |
Boolean |
Description |
For the codelist item that is specified in the brackets, returns a value that indicates if the checkbox for the codelist item is selected. You can also use this property to select or deselect the checkbox for a codelist item. |
Purpose |
Use this property to determine whether a checkbox has been selected. For example, to disqualify subjects who are using aspirin, you can create a list of common OTC drugs with a checkbox next to each. value = this.itmOTCMeds.Selected[this.itmOTCMeds.clOTCMeds.Aspirin] when value is true issue query on this.itmOTCMeds: Subjects on an aspirin regimen are not eligible for the study. You can also use the property to programmatically select items. To select an item, use a SetValue action, setting the value to True for a selected checkbox or False for a deselected checkbox. |
