Set Value Action dialog box—Option descriptions
Use the Set Value Action dialog box to set the value of an item based on the outcome of a rule.
Option |
Description |
Item |
Item for which the value is set. You can type a name or drag an item from the Data tab. |
Value to set the Item |
Value for the item. You can type a value or drag information from any of the tabs. |
Reference tabs—Available components |
List of the components that are available for use in the rule being defined. By default, these tabs appear on the right side of the dialog box. When you select a tab, the Reference section appears, with tabs along the bottom edge. |
Data tab |
The available study objects appear in a tree structure similar to the Project Explorer. |
Functions tab |
The available functions appear in a tree structure organized by class. Note: Functions are defined in the Study Editor or Library Editor. |
Constants tab |
The available constants appear in a tree structure organized by class. Note: Constants are defined in the Study Editor or Library Editor. |
Data Mappings tab |
The components of the available mappings appear in a tree structure similar to the Project Explorer. |
Show All checkbox |
When selected, all available study objects as well as their properties appear. When not selected, only the available study objects appear. |
