Set Review State Action dialog box
Use the Set Value Action dialog box to set the review stage of a form based on the outcome of a rule.
Set Review State Action dialog box—Option descriptions
Option |
Description |
Form |
Form for which the review state is set. You can type a name or drag a form from the Data tab. |
ReviewState |
Review state to set. |
Review Stage |
Review stage to set in the review state. |
Review Stage expression |
Expression for the review stage to set in the review state. |
Comment (optional) |
Optional text describing the action. |
Reference tabs—Available components |
List of the components that are available for use in the rule being defined. By default, these tabs appear on the right side of the dialog box. When you select a tab, the Reference section appears, with tabs along the bottom edge. |
Data tab |
The available study objects appear in a tree structure similar to the Project Explorer. |
Functions tab |
The available functions appear in a tree structure organized by class. Note: Functions are defined in the Study Editor or Library Editor. |
Constants tab |
The available constants appear in a tree structure organized by class. Note: Constants are defined in the Study Editor or Library Editor. |
Data Mappings tab |
The components of the available mappings appear in a tree structure similar to the Project Explorer. |
Show All checkbox |
When selected, all available study objects as well as their properties appear. When not selected, only the available study objects appear. |
