Resolve validation errors and warnings
You can build a deployment package only if validation produces no errors and no warnings, or if you resolve, acknowledge, or choose to ignore all warnings. A warning indicates that the study is valid, but the behavior of the study in InForm might not be expected or desired.
- Open the Baselines tab.
Tip: If you don't see the Baselines tab, at the top left of the page, select View, and make sure Baselines is selected. - Review the Description for each message for which the Validation Type is Error or Warning.
- Double-click the error or warning.
The error or warning may occur in multiple locations. If so, correct them one at a time.
- Update the study definition as necessary to correct each error or warning, and save your changes.
