Ignore validation warnings
You can build a deployment package only if validation produces no errors and no warnings, or if you resolve, acknowledge, or choose to ignore all warnings. A warning indicates that the study is valid, but the behavior of the study in InForm might not be expected or desired.
You ignore all warnings as a group. You cannot select specific warnings to ignore.
- Open the Baselines tab.
Tip: If you don't see the Baselines tab, at the top left of the page, select View, and make sure Baselines is selected. - Select a baseline with the status, Invalid with Warnings.
- Examine the warning messages.
- If you decide to ignore the warnings, click Ignore Warnings.
The status of the validation baseline changes to Valid with Warnings.
