Troubleshooting issues with Help
If any of the tabs do not appear when you open the Help from the Help menu, add the name of the application server to the list of trusted sites.
- In Internet Explorer, select Tools > Internet Options.
- Select the Security tab.
- Select Trusted Sites, and click Sites.
- In Add this Web site to the zone, type the address that the client application uses to connect to the application server.
- Click OK until you return to Internet Explorer.
