Central Designer Administrator terms
The Central Designer Administrator application uses the following terms.
Definitions of Central Designer Administrator terms
Term |
Definition |
User |
A person who works in the Central Designer or Central Designer Administrator application. |
Role |
A collection of rights. When a user is assigned to a role, the rights associated with the role are granted to the user. |
Right |
A predefined permission that controls access to a specific feature or activity in the Central Designer client or Central Designer Administrator client and that can be assigned to one or more roles. |
Collaboration note type |
A classification used to identify the type and purpose of a collaboration note. |
Task type |
A classification used to identify the type of the task and the way the task is used. |
Supported locale |
A supported language or language variation. |
Custom property |
A user-defined or default characteristic of a study object. The Central Designer Administrator application includes some predefined custom properties. |
Keyword |
An identifier that is associated with users and study objects to facilitate more powerful and efficient searches. A keyword can be system-generated or user-defined. |
Category |
A hierarchical grouping of keywords. You can create categories only from existing keywords. A category can be automatically generated or manually generated. |
