Searching a catalog for a keyword
You can search for keywords in the Study Objects catalog and Users catalog.
Note: The search in both catalogs is case sensitive. For example, if you type Designer in the search field, the search engine does not detect the designer keyword.
- Click the Catalog button.
- In the Catalog section, click one of the following links:
- Study Objects—The Study Objects Catalog workspace appears.
- Users—The Users Catalog workspace appears.
- In the Click here to search or create a new Keyword field, type a keyword.
As you type, a real-time search of the list is performed, and the first keyword that matches the text that you type is selected.
Note: If you type a keyword that is not in the list, and you want to add it to the list, press Enter.
