Creating and deleting a keyword
Keyword names must be unique. Keywords are also case sensitive—for example, radiotherapy and Radiotherapy are considered unique keywords.
Note: If you delete a keyword that is used to categorize a study object or user, the study object and user are no longer searchable by the keyword.
Note: You cannot modify or delete a user keyword.
To create a keyword in a catalog:
- Click the Catalog button.
- In the Catalog section, click one of the following links:
- Study Objects—The Study Objects Catalog workspace appears.
- Users—The Users Catalog workspace appears.
- In the Click here to search or create a new Keyword field, type a keyword, and press Enter.
or
Right-click the Keywords list, and select Add, or press Ctrl+N. In the dialog box that appears, type a keyword, and press Enter.
The keyword is added to the list for the selected catalog.
- Click Save.
To delete a keyword:
- In the Keywords list, select a keyword, and press Delete.
or
In the Keywords list, right-click a keyword, and select Delete.
- Click Save.
