Previous Topic
Next Topic
Book Contents
Create the database and tablespaces
After you install the Oracle database software, create the database instance and tablespaces. Make sure the Oracle server has sufficient space to accommodate the new tablespaces. The Central Designer software uses the following tablespaces by default.
Tablespace descriptions and sizes
Tablespace
Description
Minimum size
DESIGNER
Main data tablespace
100 MB.
A 16k (16384 bytes) block size is required.
Note: Depending on usage, you might need to increase the MB size.
SYSTEM
500 MB.
SYSAUX
250 MB.
TEMP
Temporary tablespace
Always present in the Oracle database.
UNDOTBS1
200 MB.
Note: The tablespace names provided are the default names. Any names can be used for the tablespaces.
If you use non-default names, you must specify them during the installation of the application server (by clicking Advanced on the Database Parameters page), so be sure you take note of them.
Send Feedback
