Registering .NET assemblies
You must register the .NET assemblies to the Global Assembly Cache (GAC) after the initial installation, and each time you apply a patch.
- Oracle.DataAccess.dll
- Policy files that redirect older Oracle.DataAccess.dll versions to the one installed
To add the assemblies to the GAC:
- Open a command prompt as an Administrator.
- Navigate to the directory that contains the assembly to add to the GAC (<oracle home>\ODP.NET\bin\4).
- Execute the following command:
oraprovcfg.exe /action:gac /providerpath:Oracle.DataAccess.dll
- Navigate to the directory that contains the policy files to add to the GAC (<oracle home>\ ODP.NET\PublisherPolicy\4).
- Execute the following commands:
OraProvCfg.exe /action:gac /providerpath:Policy.4.112.Oracle.DataAccess.dll
OraProvCfg.exe /action:gac /providerpath:Policy.4.121.Oracle.DataAccess.dll
OraProvCfg.exe /action:gac /providerpath:Policy.4.122.Oracle.DataAccess.dll
