Previous Topic
Next Topic
Book Contents
System requirements: Client computers
Feature
Client requirement
Operating system
One of the following:
  • Windows 8 Version 6.3.9600 Build 9600, Enterprise Edition
  • Windows 10
  • Windows Server 2012 R2 Standard
Processor
Dual CPU Core i3, 2 GHz or higher
Display
  • 1024 x 768 or greater resolution
  • 256 or more colors
Note: To avoid display issues in Central Designer, Oracle recommends that you do not set the Windows display size setting to Medium - 125%.
Memory
Minimum: 4 GB
Recommended: 8 GB
Note: If the computer has 512 MB or less, you cannot install the client applications.
Disk space
In addition to the space required for the operating system:
  • Approximately 150 MB for both the Central Designer software and Central Designer Administrator software
Software
  • Adobe Acrobat Reader 9 (for documentation)
  • Microsoft .NET Framework 4.6.2 or 4.7.2
  • Microsoft Internet Explorer 11 or Edge
    Edge version 79 or later requires enabling ClickOnce. For more information, see Enabling ClickOnce support for Microsoft Edge version 79 or later in the Installation Guide.
Bandwidth between the application server and client computers
Minimum: 1.5 Mbps (T1)
Recommended: 5 Mbps
Send Feedback
